09-23-2020 10:07 PM in
Galaxy ASolved! Go to Solution.
- Tags:
- GalaxyA51
6 Solutions
09-23-2020 10:29 PM in
Galaxy A- Mark as New
09-23-2020 10:48 PM in
Galaxy Aplease check this petition
http://chng.it/KzHLngSH
09-23-2020 11:02 PM in
09-24-2020 07:23 AM in
Galaxy AGuide to enter safe mode.
1Power off the device.
2Now turn on your device by pressing the Power key . When Samsung logo appears, press and hold the Volume down key .
If your device functions correctly in Safe Mode, it is most likely that the issue lies with a 3rd party application that can be uninstalled to resolve the problem
Galaxy A1. Settings >developer option >background process limit >choose no background process
2. Disable auto sync
3. optimise your device often using with device care app
4. on device care app >battery >3vertical dots >settings > put unused apps to sleep
5.Disable always on the display >if u don't use,
6. On the device care app>battery >disable background process which apps consumes most the battery
7. Turn of Gps, Bluetooth when not in use
doing this things can may help your device battery last longer
09-24-2020 11:51 AM in
09-24-2020 09:00 AM in
09-24-2020 10:43 AM in
