11-07-2020 10:59 PM in
Galaxy A- Mark as New
11-07-2020 11:22 PM in
Galaxy A1. Connection>more connections settings> disable nearby device settings.
2. Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
4. Long press on each app specially 3rd party app(LIKE FACEBOOK, YOUTUBE) and rarely used apps and also ON "GOOGLE APP" as well, then click on>app info> go to these 3 options below on by one
6. Go to settings > Google > on device sharing> check which 3rd party apps present there for e.g. if you use paytm , paytm will shared data to show recommendation and suggestion which also cause battery drain
7. Go to settings > account and backup> account > check which app syncing automatically there, and if any app which not necessary to auto sync then click on it and "disable sync"
8. Go to settings >apps>search "weather" >click on settings icon right side > change "auto refresh" settings as per your requirements and disable some unnecessary reminder. ( due to auto refresh it continuously consuming battery)
10. Google >click on 3dot at right top corner>usage and diagnostics >off this option.
11-08-2020 12:25 PM in
Galaxy Ahttps://r2.community.samsung.com/t5/Tech-Talk/Battery-saving-tips/td-p/2920797
11-19-2020 05:54 PM in
Galaxy ADear Samsung Member,
Please be assured and to resolve "charging" issue kindly follow the given below step:
>>Check charger functionality:-Request you to check the charger functionality with a different device or try to charge the same device with a different charger.
And to resolve "Battery drainage" issue kindly click on the link below:
http://www.samsung.com/in/support/skp/faq/1101689
If the issue still persist, kindly register your concern in Samsung Members app (Samsung Members app > Get help > Feedback > Error report/ask question).
Note: Please send device log files within 15 minutes of issue occurrence along with the exact issue details.
