11-07-2020 12:44 AM in
Galaxy ASolved! Go to Solution.
2 Solutions
11-07-2020 12:48 AM in
Galaxy A2nd due to huge notification enable.
for e.g ; Google has huge notification which we don't need at all see image just scroll down image and check how many notification it does have.
So do these settings to stop, which consume unnecessarily.
1. Connection>more connections settings> disable nearby device settings
2. Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
11-07-2020 09:47 AM in
Galaxy A- Mark as New
A. Wifi scanning
Galaxy A3. Device care>battery >power mode>select "optimised" and "adaptive power saving".
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
4. Long press on each app specially 3rd party(LIKE FACEBOOK, YOUTUBE) and rarely used apps and also ON "GOOGLE APP" as well, then click on>app info> then go to these 3 options below on by one
5. Go to settings> privacy > permission manager > location> and check which app have accessing your location all the time and if not using that apps then deny access or set as " allowed only while in use"
6. Go to settings > Google > on device sharing> check which 3rd party apps present there for e.g. if you use paytm , paytm will shared data to show recommendation and suggestion which also cause battery drain
7. Go to settings > account and backup> account > checkwhich app syncing automatically there and if any app which not necessary to auto sync then click on it and disable sync.
8. Go to settings >apps>search "weather" >click on settings icon right side > change "auto refresh" settings as per your requirements and disable some unnecessary reminder. ( due to auto refresh it continuously consuming battery)
10. Google >click on 3dot at right top corner>usage and diagnostics >off this option.
11-07-2020 12:49 AM in
Galaxy AA. Wipe Cache Partition.
Steps to perform.
1) Turn off the device.
2) Press and hold the Volume Up key and the spower button.
3) When the Android logo displays, release all keys.
4) Press the Volume down key to navigate and select "Wipe cache partition".
5) Press Power key to select. When the wipe cache partition is complete, Select Reboot System.
6) Press the Power key to restart the device.
B. Reset App Preferences.
Settings >Apps> Tap on Top Right 3Dots and select Reset App preferences.
11-07-2020 10:03 AM in
11-07-2020 10:49 AM in
Galaxy Ahttps://r2.community.samsung.com/t5/Galaxy-M/Tips-to-improve-battery-life/td-p/5039156
11-07-2020 10:50 AM in
