Highlighted
Hi guys
I am facing some battery draining  issue in my A50 at night  charging is 50% and I woke up my battery remains only 35% or 40% at night battery drain more than day without using the phone
  Any solution if you then plz tell me comments section
   Thank you
16 Comments
Highlighted
hello
i have also faced the same issue in my galaxy a30
i also went to the service centre , they just installed a software , but it too didn't solve my problem.
but i got a solution for this problem and it is solved now.
the all you have to do is not clear your ram completely , don't close all your background apps at night , just let some of the apps running in background like camera , calculator or anything that you want .
It helped me and surely it will help you to solve your battery drain issue
Highlighted
welcome broo
actually i have already face this problem and i also solved like this
Highlighted
and please let me know if this helped you or not
thanks
Highlighted
sure
Highlighted
Bro its amazing it work thanks
Highlighted
Hi guys
I'm facing some battery draining issue in my A7 2018 model at night ex army charging 90% an I woke up my battery remains only 45% at night battery drain more than day without using the phone
Highlighted
you ex-army just point a m416 at the phone and put exactly 2 bullet's in than....and empty the rest of the mag ar your charger....i am pretty sure your problem will be solved...
Highlighted
what is the meaning of ex-army charging bro?
Highlighted
same question 🤣🤣🤣🤣.....like ex-army people come to their house to charge their phones 🤣🤣🤣....or they are ex army.....does being ex army makes charging faster or battery better......so many questions man😂😂😂
