battery drain cause on A51
(Topic created on: 09-12-2020 02:04 AM)
Amank2020
So this light sensor is draining **bleep** tons of battery and this is reducing the Sot by almost 2 hours.  Please fix it on priority basis samsung .... No reset doesnt fix it .
24 Comments
lazypanda7
how did you get the sensor battery consumption to show?
Amank2020
under device care > battery > whatever app you wana see tap it
Amank2020
stop replying with useless stuff please!! i know how to use my phone , never said i am getting bad battery life , just read !!
Ehsank
so, brother, i deleted all my useless comments👍👍
Amank2020
no offense bro , i know this issue can only be fixed by samsung on software level .... xd just want them to see it and fix it asap
Blackwinter
ehansk 😂😂😂😄😃😉
Ehsank
@Blackwinter, i suggest him to disable auto brightness and gave him some extra battery savings,
but he already knows everything, and saying my comment useless so i deleted my all comment.
and i think everyone who knows better definitely advise him to disable auto brightness, as Samsung uses camera light sensors for auto brightness, not dedicated sensor for that.
and see one BA (RohanGhag) also suggested him samething.
Ehsank
but anyhow ,I delete as he got angry on my comments. and i think he know the things better
Amank2020
ofc i know things better than you and also i dont go on begging for likes and solution ticking in every post :) Grow a pair and stop pasting nonsense everywhere
