Highlighted
Help Samsung
Please if any admin is reading, the battery drain issue in a50 is worst after October update.
If I keep phone idle only then battery is not draining. But the minute I turn the screen on, battery starts discharging by 1% every 45 second!
I am not heavy user. I don't have any games on my phone. I have limited social media app and watch few videos. I don't use AOD and turned off auto brightness. My Bluetooth and wifi are switched on only when I need. But still battery keeps draining.
Please fix this issue. Maybe in order to improve connectivity, they've compromised with battery life?
Please fix this asap.
14 Comments
Highlighted
Don't worry, if this is the issue , then in next updation it will be resolved
Highlighted
hopefully bro
Highlighted
stop using fancy wallpapers also
Highlighted
how are you so sure I must be using " fancy wallpapers"? do you know me personally? I use black wallpapers btw, as I am not a kid to like fancy stuff
Highlighted
i dont have to know you personally to comment on such topic, people like to use fancy wallpapers if you look around this app you will come to know. In general people do use fancy wallpapers
Highlighted
a50 becomes very slow and buggy after october update. samsung is no more concentrating on our device
Highlighted
I use 6gb ram version of A50 but now I feel a lag time while using apps.
Highlighted
Happens with my a70s
Highlighted
yes bro, same is happening. Mine is 6gb too but still very laggy
