Sound problem. A03s
(Topic created on: 10-26-2024 06:10 AM)
RAJKUMAR231
Samsung galaxy a03s playing a song or vedios automatically sound output decrease. When device restart them full sound come back.
cs_member8
Dear Samsung Member,
● Clear app cache through Device care:
→ Settings > Device care > Storage > CLEAN NOW.
● The clear cache memory of a particular application:
→ Settings > Apps > Now pick the app that you like to clear off the cache memory > Storage > Clear Cache.
● Reset the device Settings: Settings > General Management > Reset settings>Reset all settings to their default.
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open the Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select Error report > select the appropriate issue category> Type your query and send).
