logix
04-16-2021 10:28 AM in
Battery draining upto 10% being idle for 7 to 8 hrs
Is this normal or should i be concerned
Solved! Go to Solution.
33 Comments
- « Previous
- Next »
Not applicable
04-17-2021 05:47 AM in
Facing Same issue
Not applicable
04-18-2021 04:42 AM in
I have visited customer service center. They suggested software reinstallation from service center.
Not applicable
04-18-2021 02:37 PM in
It only needed one Restart. After restart I kept phone under observation and found, battery draining issue gone.
Mishal786
05-16-2021 11:07 AM in
My Samsung Galaxy A52 idle battery drain is 5 to 6% in 10 hours when the mobile data is off
Is this normal?
Because 4500mah is considered good capacity battery in the smartphone industry should I be concerned about this?
Is this normal?
- « Previous
- Next »
