Samsung a05s battery percentage stuck issue.
(Topic created on: 08-13-2024 06:58 AM)
NiruA05s
Samsung a05s one ui 6.1 update (July update) has battery percentage stuck issue and battery swelling issue.
Don't update your Samsung a05s mobile (July update)
6 Comments
කස්ටම කෙයා එකට යන්න
thenuka_jay
Developer option enable ද?
Restart කරල බැලුවෙ නැද්ද?
NiruA05s
Not working.
ChNav
Try to boot into safe mode and check whether the issue is fixed. If not try a system reset.
To boot into safe mode, hold down the physical power button to get to the 'Shut down' menu that will offer three options – Power off, Restart, and Emergency Mode (if enabled lockdown mode). Long press the 'Power off' button on-screen and then tap 'Safe mode' to restart the device in Safe Mode.
NiruA05s
ChNav
Have you tried to boot into the safe mode check if the issue is fixed
