Resolved! Solved
Samsung A71 small led light blinking on screen
(Topic created on: 11-01-2020 10:45 AM)
sivap
Hi
I bought samsung a71 mobile 1 week back when I am calling to any number I am seeing one small led light blinking on screen. I just want to confirm is this is issue or not and that led also when I am taking on loudspeaker it is not coming only on in ear it is coming
sir it's a proximity sensor which gets enabled when we call so it's not an issue and only works when call is on earpiece it doesn't work in loudspeaker mode so don't worry
if my comment was helpful than click on the 3 dots near my comment and click accept solution
6 Comments
sivap
thanks brother. solution accepted.
Members_lmCcplL
Hello, I solved the problem of low lighting in games. I only did everything on the Samsung a71
Neel1202
that dot is proximity sensor, nothing to worry, i was also scared when i 1st saw it in my A71
SrajTech
Its the proximity sensor integrated under the pixel of display
Please accept as solution
a71user777
if your not in the call but still the proximity sensor is still blinking how to solve this problem sir
