NeedHelp06
Up to about 2 weeks ago it was working fine but right now I have to tap the volume up and down keys to adjust the volume. I prefer holding the volume keys in every single situation to adjust the volume. I have disabled all the shortcuts that could have been assigned to holding the keys. I did a soft reboot about last week and that solved the problem for a while but now that won't even work. I do not have any third party apps that affect volume keys or anything. I know its not a hardware problem since holding the keys for anything else works fine. I did  wipe the  partition cache it has not helped. Please assist as in coming calls and media are troublesome to operate for me while tapping the keys.
Comment
3 Comments
Galaxy_A52
go to nearby service center and check
Samsung_Support1
Dear Samsung Member,
Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
Dr_Bharat
Same problem occurred with my samsung A50 after factory reset..
