SLOW CHARGING, OVERHEATING AND BATTERY DRAINING
(Topic created on: 07-18-2020 01:40 PM)
ĐîkÜ
After the ONE UI 2.0 Update My A50 is now taking 3 hours to get fully charged and also it heats during usage of normal applications and also battery drains too fast gets only 2 hour sot.
7 Comments
Gaganveer
agree with u. phone heating too much
ĐîkÜ
did 3 times...what else
yes too much hearing and lagging UI in a50
ĐîkÜ
need improvement a lot in A50
PaTiL10
reset phone
cs-member13
Expert Level 4
Dear Samsung Member,
Please be assured and to resolve "charging" issue, we would like to inform you that kindly switch off Handset for 5 minutes to cool down and recheck if its working fine.
And Samsung customer’s safety is on top priority that is why this concept is introduced with logic that whenever handset temp. or ambient air temp. goes up to certain set limit, then device automatically restrict fast charging or even some time stops charging. But post device temperature reaches to normal after cooling down the set, then automatically set starts charging normally (This is implemented in all Smartphone models from year 2019)
And to resolve "overheating" issue kindly follow the given below steps :  https://www.samsung.com/in/support/mobile-devices/why-the-heating-issue-occurs-in-mobile-device/
And to resolve "drainage" issue kindly follow the given below steps : http://www.samsung.com/in/support/skp/faq/1101689
If the issue still persist, kindly register your concern in Samsung Members app (Samsung Members app > Get help > Feedback > Error report) along with Video or Screen-shots. This will help us to further investigate and resolve your concern.
Note: Please send device log files within 15 minutes of issue occurrence along with the exact issue details.
manojkumaar
yes
