Highlighted
Dear Samsung please provide better battery service and optimization I'm using samsung galaxy a50 6/64 gb variant the battery is very bad. And lags many times even though i have 6 gb variant.  And it heats extremely in pubg.. i don't care about android 10 update just give me a update which contains better camera quality because it's awful not expected these kinda quality from a 20k phone.
Please do fix these things.
Battery Life
Optimization
Camera quality
And lags issue.
8 Comments
Highlighted
y my outgoing calling is not allowed
Highlighted
you will get it for sure
Highlighted
plz accept as solution by taping three dot in my reply
Highlighted
yes heating issues and faster battery drain
Highlighted
all a50 updates are having battery drain and heating issue for time being either use Google lite apps or try resetting phone or turn in data saver trying to put less load on network chips to reduce heating and also u could use Google files go app to try to remove junk
Highlighted
try also samsung members interactive checks and optimisation checks try device care section in settings don't install 3rd party apps and use only Google or microsoft certified softwares in mean maybe new one ui2.1 will prevent these problems currently it'll be rolling out for s20 and note 10 but it'll reach a series and m series gradually
Highlighted
Highlighted
Dear Samsung Member,
Apologies for the delay in response. However, understanding the criticality of the situation; we had to ensure the well-being and safety of our employees which led to the delay in response.
Hope your issue is resolved. In case the issue still persists please follow the below mentioned steps.
  1. Reset camera settings: Click Camera > Go to Camera Settings > Reset Settings
  2. Clear cache memory of a particular application: Settings>Apps>Select particular app (e.g. Samsung Internet)>Storage>Clear Cache.
Overheating: For further details please click on the mentioned link: https://www.samsung.com/in/support/mobile-devices/why-the-heating-issue-occurs-in-mobile-device/
Battery related Concern: For more information, you can also follow given link:
https://www.samsung.com/in/support/mobile-devices/samsung-mobile-battery-drain-issue/
For further assistance, register your concern in Samsung Members Application (Samsung Members App > Feedback >Error report > Attach log file for any issue)
