I hope to fix errors, slow charging, and always repair the battery quickly, and
(Topic created on: 07-17-2024 11:35 PM)
ogufjg
I hope to fix errors, slow charging, and always repair the battery quickly, and fix the internal storage memory that is full and there are no files in it, nor large files that are full, but they are empty. I hope for help in solving the problem and errors in using the internal storage memory, correction, and automatic storage.Please fix the hardware buildup and lag buildup. Please install and fix errors in Android. Help in fixing applications, devices, games, products, tools and external programs that are slow to use with the Internet and Wi-Fi, always interrupted and delayed in starting use. All products and applications are not compatible with the device. Please fix errors in Android and fix to the default general mode and exit from the slow time and fix the delay in the default settings and the default application settings and the permissions in the system application are automatic. Assistant in Google tools and products and Samsung Galaxy Automatic for all deficiencies and downloading and analyzing and fixing all errors and automatic correction and transfer and improving and developing everything automatically remotely. I did not find manual software and Repair and compatibility with applications, devices, games, products, tools and external programs. Thank you, the staff and administrators and enlightened Google products. I own a Samsung Galaxy A12 phone and I face whether usingThe device heats up when using games or applications. The official website is not accurate in Google productsAnd repairing the accumulation and composition of devices and applications, correcting spelling errors, devices and products, correcting all wrong procedures, improving browser speed, and providing communication balance and the Internet Atheer. I would like to fully examine Android and correct errors in all parts of the phone, device, products or applications, improve them, develop and remove the unused system or unused files, and give the phone Or the device or mobile phone has full rights for default use and correct settings
Samsung_specialist
We understand that you are facing multiple challenges including slow charging, errors with internal storage, and performance issues. Here are some steps we recommend to address these concerns:
1. Slow Charging and Battery Issues:
- Ensure you are using an original Samsung charger and cable.
- Check for any damage to the charging port and cable.
- Consider performing a battery calibration by fully charging and then fully discharging the battery.
2. Internal Storage:
- Verify if there are any unnecessary files or apps consuming space.
- Clear cache and data for apps that may be using excessive storage.
3. Performance and Lag:
- Ensure your device's software is up to date. Go to “Settings” > “Software update” > “Download and install”.
- Restart your device to clear temporary system glitches.
- Boot your device in Safe Mode to see if third-party apps are causing performance issues. If the performance improves, uninstall recently added apps.
4. Application and System Errors:
- Check for app updates in the Google Play Store and Galaxy Store.
- For any system errors, a factory reset may help, but ensure you back up all important data before proceeding. Navigate to “Settings” > “General Management” > “Reset” > “Factory data reset”.
5. Wi-Fi and Internet Issues:
- Restart your router and device.
- Check if other devices have similar connectivity issues to determine if the problem is with the network or the device.
6. Device Heating Up:
- Avoid using multiple resource-intensive apps simultaneously.
- Remove any phone case while using the device for extended periods to help with heat dissipation.
For a more thorough diagnosis and solution, we recommend visiting a Samsung Service Center where our technicians can provide hands-on support.
