I have a problem with my figure print on Samsung a16 it's not working please 😕
(Topic created on: 01-02-2026 12:49 AM)
nastyu
Please help me out Samsung
Hi nastyu
Here’s how to troubleshoot and potentially fix the fingerprint sensor on your Samsung Galaxy A16 (not working / not responding) — plus what to do if it’s a hardware issue:
Common Fixes You Can Try
🔄 1. Restart the phone
A reboot can clear temporary glitches and often fixes fingerprint errors. �
DigitBin
🧼 2. Clean the fingerprint area & your finger
Make sure the sensor and your finger are clean, dry, and free from oil / lotion. �
Samsung
Even if it’s a side-mounted sensor on the power button (as on the A16), dirt can still block it.
📱 3. Remove and re-register fingerprints
Old or corrupt fingerprint data often stops recognition.
Steps:
Settings → Biometrics and security → Fingerprints
Delete the old prints
Register again (try capturing the full fingertip at different angles) �
Samsung Community
📦 4. Check screen protector / case
If your protector or case interferes with the sensor area, it may prevent proper reading.
Try removing them temporarily and test again. �
Samsung
🔐 5. Try Safe Mode
Boot into Safe Mode to check if a third-party app is causing the issue.
If the sensor works in Safe Mode, then an app you installed is interfering. �
Samsung Community
🔄 6. Software update
Check: Settings → Software update → Download and install
Sometimes bugs are fixed in newer updates. �
Technobezz
🧹 7. Clear cache partition
Clearing cached system data can fix sensor problems (won’t delete personal files).
Turn off device → hold Power + Volume Up (to recovery) → select “Wipe cache partition.” �
Mobile Internist
⚠️ 8. Factory reset (last resort)
If nothing else works, a factory reset often fixes software bugs — but back up your data first.
Settings → General Management → Reset → Factory data reset.
This may fix deep system issues if the sensor stopped working after an update. �
Samsung Members
🧪 If It Still Doesn’t Work
🔧 Likely a Hardware Problem
If the sensor is physically damaged or completely unresponsive even after all software fixes, it may be a hardware failure — especially if:
It worked before and suddenly stopped with no software change,
It never registers new fingerprints,
It shows “Fingerprint sensor not responding.” �
Samsung Community
In that case, the best option is to take your phone to an authorized Samsung service center for repair or replacement under warranty (if applicable). �
Samsung Community
