DeepPS
10-04-2024 10:34 AM in
After the new update of Android 14, One UI 6.1, Security patch level, 1st August 2024, in Samsung Galaxy A23 4G, I am facing heating and battery drain issue.
I have never faced battery drain and heating issue before.
I am charging the phone with the official charger with the same original cable that came with the box. The charger condition is good.
Earlier I used to charge the phone only once in two days but now after updating, I am charging the phone twice a day.
And the phone is heating up badly 😞.
Solved! Go to Solution.
goodthings
10-11-2024 10:02 PM in
4 Comments
goodthings
10-04-2024 02:01 PM in
Kindly reset factory data with backup then try to it's again. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
DeepPS
10-11-2024 07:37 AM in
Not working bro
goodthings
goodthings
10-04-2024 02:02 PM in
Your's most welcome to here.
