08-07-2020 10:26 AM in
Galaxy ASolved! Go to Solution.
08-07-2020 11:19 AM in
Galaxy AACCEPT AS SOLUTION BY CLICKING ON 3DOT AT MY COMMENT
08-07-2020 10:33 AM in
Galaxy A- Mark as New
08-07-2020 10:38 AM in
08-07-2020 10:45 AM in
08-07-2020 10:35 AM in
08-07-2020 10:37 AM in
08-07-2020 11:18 AM in
Galaxy A1. Connection>more connections settings> disable nearby device settings
2. Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
3. Google >click on 3dot>usage and diagnostics >off this option
4. developer option >background limit>no background processes.
5. Long press on each app specially 3rd party and rarely used app>app info>
6. Device care>battery >select "optimised and adaptive power saving.
Steps to enable developer option
settings >about phone>software information >then u find build number >tap 7 times>then back to settings
and at end of settings one new option called developer option
click on it and find that option
08-07-2020 11:29 AM (Last edited 08-07-2020 11:33 AM ) in
Galaxy Afirstly, i used A30s, when i update my Phone to Android 10 after that really my phone runs very smoothly and it gives battery backup around 24hrs on medium saving mode and 18-20hrs for optimised setting. but after June, 2020 update my same phone with very smooth experience it gives 12 hrs battery backup at optimised setting and 14-16 hrs on medium battery saving settings..
so, my friend i don't think ki bas 20 din k ander mobile ki battery itani degrade ho sakti hai, kyuki Android 10 update 2nd june ko mila aur june security patch 20th june ko.. na hi maine koi naye heavy app download kiye us dauraan aur naahi mai heavy gamer hu...
and for your knowledge i already send error report to service center regarding this issue, they answered as usual robotic type...
so i conclude that samsung send some bugs through update to degrade the battery as well as our models too...
bcoj it happens with all the series..
