Resolved! Solved
Galaxy A30s battery drain problem
(Topic created on: 11-16-2020 09:37 AM)
wasifsuham
My galaxy a30s got a new software update recently and after that, it drains battery faster than usual. What shall I do now?
2 Solutions
Ehsank
one of the main reasons of battery drain is background activity,
even you close apps but they uses ur battery and running in background unnecessary, see image(1) and read the statement.
2nd due to huge notification options.
for e.g ; Google has huge notification which we don't need at all see image(2) just scroll up and down and check how many notification it does have.
So do these settings to stop, which consume battery unnecessarily.
1. Connection>more connections settings> disable nearby device settings
2. Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
Ehsank
Besides above settings do some more settings to save more battery life and observe for next 1-2 days, it will give a noticeable difference
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
4. Long press on each app specially 3rd party(LIKE FACEBOOK, YOUTUBE) and rarely used apps and also ON "GOOGLE APP" as well, then click on>app info> then go to these 3 options below on by one
5. Go to settings> privacy > permission manager > location> and check which app have accessing your location all the time and if not using that apps then deny access or set as " allowed only while in use"
6.  Go to settings > Google > on device sharing> check which 3rd party apps present there for e.g. if you use paytm , paytm will  shared data to show recommendation and suggestion which also cause battery drain
7.  Go to settings > account and backup> account > checkwhich app syncing automatically there and if any app which not necessary to auto sync then click on it and disable sync.
8. Go to settings >apps>search "weather" >click on settings icon right side > change "auto refresh" settings as per your requirements and disable some unnecessary reminder. ( due to auto refresh it continuously consuming battery)
10. Google >click on 3dot at right top corner>usage and diagnostics >off this option.
13 Comments
Ehsank
A. Wifi scanning
Ehsank
A. Adaptive battery
Ehsank
and if my given settings/comments will work for you then you can accept as solution by CLICKING on 3DOT at my comments
SAINIGe
can you tell me that nearby share is available now in galaxy A30S
Ehsank
why bro, nearby share is by Google it should be there
SAINIGe
but Samsung call support team said me that it removed from all A30S
Ehsank
but how can say like that, it is from Google itself, not from Samsung
where did you contact them?
SAINIGe
call and smart tutor
SAINIGe
after update Google play services got nearby share thanks
