justpranav
02-15-2020 11:00 AM in
Samsung please fix battery drain issue in upcoming updates
4 Comments
GaganBro
02-15-2020 11:03 AM (Last edited 02-15-2020 11:04 AM ) in
Galaxy ADid you recently installed any new app before the battery draining issue has been noticed?
If the battery draining is caused by a software issue then the main culprit behind it can be a bad app. So check whether you have installed any new apps, if did please uninstall it and restart your phone and check whether the battery life has been bettered. To uninstall an app go to Settings->Application Manager.
justpranav
02-15-2020 11:09 AM in
I did not install any new app before battery draining issue and also I recently factory reset my mobile but still battery draining issue is there
vk0952
02-15-2020 11:45 AM in
Or reinstall ur system again
Samsung_Support 2
Expert Level 3
02-17-2020 06:00 PM in
Galaxy AHi there,
To resolve the issue please follow the troubleshooting steps provided in the given link: http://www.samsung.com/in/support/skp/faq/1101689
Regards,
Team Samsung Members
