Galaxy A26 Charging Issue (Battery charge time left not showing)
(Topic created on: 06-19-2025 09:38 PM)
drwells
I am using Galaxy A26, I am having a charging problem, I charge my galaxy A26 with the original 25watt adapter, but after 20-25% super fast charging, there is no charging time left and the phone charges very slowly, until I reconnect the cable with this phone, after plugging again in the phone starts charging again with super fast mode! Is there a problem with the phone, or is the phone doing this because of the hot environment?
12 Comments
ZainSajid
Due to heat because of summer season
ZainSajid
Fan ka agy rakh k charging lagaien no problem
Umarriaz007
Grmi ne insan ki bend bja de ap fon ko beth k roo rhy ho🔥😂
Zeeshan90x
Bhai garmi to band baja hi rhi hai but sath mein phone bhi band bajana shuru kr de to phir to double band baj gai
Zeeshan90x
Same issue on my A15. I think it's because of high temperatures these days. Most phones charging speed slows down in this heat but A15 just won't charge at all after 5 to 10 percent. My charger and cable are both fine because my A06 charges fine and has no such issues. I tried turning off a lot of background stuff, data etc to keep the temperature low but still not working.
drwells
but if temperature is high so why a06 charge properly? is it only problem with a15?
Zeeshan90x
Looks like a manufacturing defect in a15. I have seen other people complain about this on their A15s here. I am a light user but my phone gets high temperature easily. I know these days most phones are getting high temperature because of high temperature environment but it's causing major issues in charging on A15. Even when the phone is not really hot it still won't charge properly. Couple of days during last week temperature was down and it was charging fine. Then temperature went 40+ again and now facing same issue.
drwells
right, may be it is some type of feature for protecting battery!!
Zeeshan90x
Yes perhaps but its a major issue to practicality of phone. As i said I am a very light user. Don't have any games or heavy apps on my phone. Other phones charge fine. Yes they also slow down a bit because of heat but not at the level of A15. It just won't charge. When I turned off fast charging in settings then it charges but takes 10x more time to fully charge. It's such a headache.
