Shd4Shahid
09-30-2021 01:21 PM in
Galaxy AWe desperately need a full battery charge alarm. This will help us to disconnect the charging as soon as its battery is full thus saving the battery overall health.
Should show this in main screen with audible notification. Users dont have to go to battery information menu to find out.
6 Comments
Saadi121
09-30-2021 09:19 PM in
Bro it's automatically circuit break if 100% complete
Because you think you put on charge its 100% and you forget to remove its not damage your battery
Its Protect your battery in this way that circuit break from charging and put back charging Ic
Shd4Shahid
10-01-2021 03:02 AM in
Please check battery section it says continuous charging reduce battery life.
FarHađ
10-01-2021 02:17 AM in
Download accubattery app from Google play store and then set the percent u want to get alarm
Shd4Shahid
10-01-2021 03:03 AM in
I don't want to use third party app 😫
FarHađ
10-01-2021 03:10 AM in
So one UI or Android doesn't have such a feature yet
Nido221
10-10-2021 09:23 PM in
Many custom roms have such features.
You can set alarms even at 80,70 or 60% battery 🔋 charge and even at particular discharge levels but never see stock ROMS providing these features.
So your only bet is to unlock the phone & use custom ROM but remember it voids the official warranty.
Hope it would help
Hope it would help
