Flash Firmware | A50 | Restart Problem
(Topic created on: 09-04-2020 07:51 AM)
FollowUrHeart
I recieved 2 Updates on June for My Galaxy A50
I recieved 1st Update on June 15 2020 (Binary Code 5)
After the Second Update On June 28 2020 (Binary Code 5), I started facing Restart Problem !
So Downgrading the Firmware to June 15 2020
Update using Odin
Will Problem Solve ???
Please Help !
Even After August Update (Binary Code 5) Problem Not Solved !
11 Comments
Not applicable
better flash it once from Samsung service center bro
FollowUrHeart
ok bro
bro is there any problem arise after Downgrading?
Not applicable
don't downgrade bro ..it's for few reasons.. 1st of all if your device support knox security service. . then it will tripped , you may have to compensate 4 or 5 built-in useful features , security of system hamper and none of the service center will take any responsibility if by chance anything happened..
Dice66
I'm facing the same issues, did you visit the customer care what did they say ?
FollowUrHeart
not visited yet bro
No Service center Near me
(more than 60 km)
if you visit pls tell the solution they said !
Samsung_Support3
Dear Samsung Member,
To resolve auto restart issue please follow below given steps:
Go to Settings > General management > Reset > Turn off auto start.
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
Dice66
I just went to the service center with the same issue they told me it's related to motherboard and I have to replace it, but I have never dropped my phone and I have never used any other charger than the one they provided.. I'm pretty sure it's just software issue but they just want me to change motherboard
FollowUrHeart
same here bro !
Definitely a Software update issue !
FollowUrHeart
never ever going to buy an Samsung Products
A Big Good Bye
