Connection problem or Invalid MMI code
(Topic created on: 05-12-2022 02:17 AM)
xJoshx
Ok so I've had a problem for awhile now about this error message and I've put my sim card into another phone and it doesn't show up on there,but when I put my sim card back into this phone (A22 5G) it just gives me that error code!
What is wrong-?
xJoshx
Then yea I can use that lol
MasterV
It might be the sim card with a fault
xJoshx
But it works in other phones??
MasterV
You must've made a mistake explaining on your original post.
Have you tried other sim cards on your phone to see if they work?
And also take a screenshot after dialing that code, I want to see what it shows
xJoshx
Ok I'll send a screen shot and test and different SIM card give me a moment
xJoshx
MasterV
All is well there, just try using a different sim and see if you'll still receive the same errors or not
xJoshx
Ok I must find a different SIM card ,I know I have one but I misplaced it so will get back to you when I have found it
pdlbishal
i have a same problem on galaxy A22 5G .
plz fixed it .
i gone a irritate from  this type of problem .
plz plzplz fixed it
xJoshx
I don't know what I did, it just went away for me
