KEVEO
06-20-2022 03:40 PM in
Guys i was using my phone
And charg it with it 33 watt adapter
Phone original adapter was 27 watts
I was 33 watt over a year and now my phone isnt picking power
Means it dont go above 1 or 2 per battery
And phone shows battery health normal
Is it phone battery problem or should i use my geniun adapter i only have adapter geniun but i dont have cable
4 Comments
s205g
06-20-2022 04:53 PM in
Obviously, you should have use the original charger not the faster one cuz it does not make a difference if your phone doesn't support that fast charging. You might also need a new battery.
eyeshabutt
06-20-2022 09:03 PM in
Dear member of samsung Pakistan
Please don't use 33 wat charger in your phone use.orignal. charger
Ramish35
06-20-2022 10:14 PM in
You should use original adapter and a 33watt won't make a bigger difference
msbhatti777
09-25-2022 07:30 AM in
I am a Samsung user since 2009 used different models
Recently purchase samsung A33. Really disappointed battery life is very pathetic. Now using with power save option with extra dim light it helps a little bit. But not satisfied.
Really not recommend this model due to battery problem
