Battery issue
(Topic created on: 12-28-2022 07:55 AM)
Ade2
I am using a33
Last full charge 21 hour but use 55 min and battery left 58%..
Plzzz guide me about this???????
24 Comments
Ali_05
Exactly for me Also same issue for
A72
zafarkakyzai
In security update all things solved
zafarkakyzai
Don't worry after next security update all things solved 😉
aakashnawab7
Agar Mobile Data/wifi, sync, gps ON the to ye Normal hai. 21 hours with 55 min SOT is fine for this battery drop.
Agar aap phir bhi check krna chahte hn to ACCUBATTERY app install kr lein. Wo app drain measure krlegi. Wahan se idea ho jayega k konsi app ya feature battery drain kr rha h.
Ade2
Thnks bro
