Battery heating and drain issue after screen replacement
(Topic created on: 04-23-2023 01:28 AM)
materwelon
So i got my screen replaced (new kit) of samsung a72 and now the battery drains very fast especially when idle and also heats up when charging.
Like after 8 hrs 60% my battery drained while on standby
Any idea what should i do now?
btw screen is original
10 Comments
MaiRonZ
Maybe your screen is second copy of your 📱
materwelon
but the screen is original
MaiRonZ
I think your new panel is faulty
Bhai 8 hours main use kr k 60% drain ho ri it's normal
materwelon
i didnt use it for 8 hrs and it drained 60 percent
Bro off location and youtube tiktok kam use kro
Because pakistan is highly temperature country yaha battery drain garmi ki waja sy fast hoti ha
Or agr ap yahi phone ly k USA UK chly jao 12 hours main 60% ho ga
aakashnawab7
Keep your device Turned off whole night, and then check for battery drain overnight.
If it drains battery even in switched off condition, then your mobile is short circuited. Most probably board.
If battery is not drained then it could be display or software issue. To diagnose that. You have to check your device under many conditions like Display testing, may be double tap to wake-up feature is faulty, or may be Panel is not good and it's draining battery because of AOD. Or it could be because of Display connector shorting.
You have to find that yourself by checking again and again your device
materwelon
Thanks alot Jazakallah khairun
