04-03-2026 08:36 AM in
Galaxy A- Mark as New
04-06-2026 12:46 PM in
Galaxy AThank you for sharing your feedback regarding battery drain after the recent update on your Galaxy A56.
Kindly note that after a software update, the device may take a few days to optimize battery performance based on your usage patterns, which may temporarily result in higher battery consumption.
We recommend the following:
- Restart your device and allow a few days for optimization
- Ensure your device is updated to the latest software version via Settings > Software update
- Check battery usage via Settings > Battery and identify any apps consuming high power
- Close unused background applications
- Reduce screen brightness and disable features like Always On Display if not needed
- Update all applications from Galaxy Store and Play Store
- Wipe cache partition (if applicable) to improve system performance
If the issue persists after a few days, we recommend visiting the nearest authorized service center for further inspection:
https://www.samsung.com/ae/support/service-center/
You can also reach us through the following page:
https://www.samsung.com/ae/support/contact/
