Battery drain issue
(Topic created on: 06-17-2025 04:29 AM)
Sayednoman
New update k bad samsung a15 ki battery bht jaldi drain hoti ha.iska kya hal ho skta ha
11 Comments
Sayednoman
samsung a15 battery drain issue after update
Shahzx
Wipe out cache partition from recovery menu
Hope it fixes it
Sayednoman
Process of this????
Shahzx
Power off the phone then press power and volume up button together untill Samsung logo pops up then a recovery menu will open. Then select wipe cache partition from the menu using volume buttons. After that reboot.
Sayednoman
Sir ye process b kya ha phr b issue wesa hi ha
Ye last walay update sa pehlay battery timing achi thi us update k bad battery jaldi drain ho rhi ha aur phone b new ha 3 month ho gye hai lya ha
ArhumAB
No bro i am using it too.
It is fine.
Do you restart your phone periodically?
Umarriaz007
Use dark mood
Sayednoman
Dark Mood use kr rhai hain latest update sa pehlay battery time behtrn tha abi jaldi drain ho rhi ha
Umarriaz007
Brother abi function zda opn hwy hain es liye
