10-20-2024 06:28 AM in
Galaxy A- Mark as New
10-20-2024 07:09 AM in
10-20-2024 07:15 AM in
10-20-2024 07:19 AM in
10-20-2024 07:43 AM in
10-20-2024 07:12 AM in
10-20-2024 07:18 AM in
Galaxy ARest we can't judge battery performance within 1 or 2 weeks.
To improve battery performance.. avoid heat..
For longer video calls, choose cool time or air conditioners.
Don't use the phone while charging or don't update anything while charging.
Charging also heats the phone after charging is finished, don't use the phone for 10 minutes.
For any system update like 2 gb..
Don't update in summer, outdoor location, in sunlight..
Extreme heating may burn lithium inside, and that will damage your display by producing lines..
For longer video calls/ games take a break of 15 minutes..
Heating kills the battery + display faster.
10-20-2024 07:04 PM in
Galaxy ADear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve your issue by the given links.
Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
You can reset your device by following the steps.
