Battery drain issue in samsung A52 4g
(Topic created on: 01-24-2023 02:34 AM)
sifi
My deviece samsung a52 4g After update in android 13 one ui 5.0 drains battery very fast. Anyone has facing this problem or any other solution of battery draining issue.
5 Comments
Nazem22
Same issue with my samsung A32 and A51
King-Boşş
Try rebooting techniques.
If not work than
report to customer care center of your region.
뷔니
You should use Protect Battery option and charge your phone upto 85%
It will help you, or I did complain this to Samsung.. They said it will be overcome in next update.. Let see
aakashnawab7
Agar update k foran baad issue aaya h to reset kr lein aap. InShaAllah theek ho jaega
ash47
Same
