Battery drain heating issue a54
(Topic created on: 09-15-2023 06:32 AM)
khuram3355
Device using only 2 days new mobile but battery drain issue so much plz fix that also heating issue
3 Comments
joomla
Same found with Samsung A34.
Samsung_specialist
Hello,
Kindly accept our sincere apologies for facing this issue, please make sure to use the original charger, and you may try to diagnose the battery from the settings > battery and device care > battery. Furthermore, kindly note that using multiple apps may affect the device's battery and it's temperature. Otherwise, we need you to contact Samsung to be able to check the device remotely. https://www.samsung.com/ae/info/contactus/
khuram3355
No app install only for using whatsapp the problem is after the software update
