Battery drain & standby battery drain too fast
(Topic created on: 08-07-2020 02:03 PM)
PPNN
I have A30 almost 1 year complete but now battery not giving good backup and main problem is that when i don't use phone the battery drain continuously... When 30% left battery in night and when i see the battery in the morning the battery 8% left ...its big problem
please help
9 Comments
Ehsank
firs bro do these settings to save more battery life
1. Connection>more connections settings> disable nearby device settings
2. Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
3. Google >click on 3dot>usage and diagnostics >off this option
4. developer option >background limit>no background processes.
5. Long press on each app specially 3rd party and rarely used app>app info>
6. Device care>battery >select "optimised and adaptive power saving.
Steps to enable developer option
settings >about phone>software information >then u find build number >tap 7 times>then back to settings
and at end of settings one new option called developer option
click on it and find that option
Ehsank
and go to battery uses section check which app consuming more battery and implement point no. 5 a b c to this app
Ehsank
definitely this will work for you just after setting and next battery charge observe specially after night situation as you said
veer
take backup give factory reset your phone or visit serive center may be slove your problem reinstall software and also send feedback to Samsung
Ehsank
and dont forget to set Google app as so many members saying that Google consuming more battery
and to go google app
go to settings >app>search for Google >
and perform this settings specially 3rd one , i attached image see there is huge notification on by default
Not applicable
sir ..please flash firmware from odin or from service center...it's happening because software holes came during update by mobile data or wifi..where accurate process is install software via smart switch or odin
Akashu18
i am facing this problem since February update. i did almost everything, factory reset, visited service centre many times but nothing changed. This problem is persistsing in the update which Samsung is not solving.
Samsung_Support5
Dear Samsung Member,
To resolve your device battery drain issue please visit this link: https://www.samsung.com/in/support/mobile-devices/samsung-mobile-battery-drain-issue/
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
Nikhilknp
Battery draining is problem for every new Samsung phone. Because of its ONE UI.
Every One UI phone has BIG Battery but still can't give single day backup.
