Battery darin problem
(Topic created on: 10-13-2025 08:53 AM)
sahanX
Beginner Level 3
Has your A35 battery drain rate increased after OneU 8?
How to fix it
2 Comments
Janith842
Yes after a major update it's quite nornal. After like 1 week after installing the update. There One UI 8 will settle and optimize for the phone. So after that the battery should be same as One UI 7 or a little bit improved.
If my comment helped you in any way. Please consider hitting the 3 dot menu of my comment and accept it as a solution.
Thank you 🙏
sahanX
Beginner Level 3
Thank you
