Battery Problem in A30
(Topic created on: 11-07-2020 03:19 PM)
SanRay2001
I found a prob in my battery that like one day when the charge went to 19% suddenly it started rapidly reducing to 10% then 5% then 0% within a minute.
And also one other thing I charged my phone till 80% then the auto restart took place as scheduled in night and after that I see is it is charged 100%
Is this a serious problem?? @interchupipi please respond to this. I need a solution from you people🙏🏼🙏🏼🙏🏼
11 Comments
vishal5685
visit samsung care
Ehsank
sorry i replied, inspite of reading that you want solution from "interchupipi "
if always happened after 19% then once go to safemode just before 19%, if this is not occurs in safemode then its a software update issue in this case you need to visit service centre and get reinstall your software update, or if in same thing happened in safemode then also go to visit service centre and explain the issue it may cause due to some hardware issue
Ehsank
steps to turn safemode;
long press on power button>
long press on power off option>click on safemode >your mobile will restart and turn into safemode.
Keep in mind that in this mode only inbuilt system app will work
SanRay2001
Can this safe mode be turned off??? And does this delete any of my data because I have never used this
Ehsank
not delete anything from your mobile, and once you enable you will get one option in notification panel to restart your device, and once restart you mobile turn into normal mode
Ehsank
and if 19% is not fixed as you said its only one day happened but your battery drain in idle mode or gradually drain then
do some settings to save more battery life and observe for next 1-2 days, it will give a noticeable difference
1. Connection>more connections settings> disable nearby device settings.
2. Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
4. Long press on each app specially 3rd party app(LIKE FACEBOOK, YOUTUBE) and rarely used apps and also ON "GOOGLE APP" as well, then click on>app info> go to these 3 options below on by one
6.  Go to settings > Google > on device sharing> check which 3rd party apps present there for e.g. if you use paytm , paytm will  shared data to show recommendation and suggestion which also cause battery drain
7.  Go to settings > account and backup> account > check which app syncing automatically there, and if any app which not necessary to auto sync then click on it and "disable sync"
8. Go to settings >apps>search "weather" >click on settings icon right side > change "auto refresh" settings as per your requirements and disable some unnecessary reminder. ( due to auto refresh it continuously consuming battery)
10. Google >click on 3dot at right top corner>usage and diagnostics >off this option.
SanRay2001
Thank you so much for making time and replying to my problem😄
Ehsank
welcome bro, but i suggest you to try all above settings and do observe for next 1-2 days and if possible you can give feedback here
and do not scared of due to its lenght😊😊
SanRay2001
Sure bro, I will check and let you know😄
