Battery Draining Problem.
(Topic created on: 10-09-2020 12:58 AM)
Not applicable
Camera Light Sensor System App Draining my battery.
3 Comments
idyllic5
If it is a main application, re-set it, and if it is a downloaded application from the store, delete it
Your phone is using your front camera as a light sensor, you can turn of Adaptive Brightness, this should solve your issue.
Please let me know if this solution was helpful.
Samsung_specialist
Hi there,
Would be best to get your device checked at a certified Samsung service center. find te nearest one to you online!
