Resolved! Solved
Battery πŸ”‹ Drain issue
(Topic created on: 08-10-2024 06:56 PM)
Rawool8
Beginner Level 4
 I switched to Samsung A35 3 days ago. All the rest is nice. But Battery is Draining fast witgout any reason. I enable Power saving(so i cannot use 5g network), Dark mode, Maximum battery protect option, butto no avail. The sitiation is as it is. With above combination even i scroll youtube for just 3-5 minute it drain by 8-9 percent. Please fix this issue as soon as possible.
Samsung lover.
goodthings
Your's device is very new so please give it some time. After some time and After some updates all is well. So please don't bothered about this issue now. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
7 Comments
goodthings
Rawool8
Beginner Level 4
Ok. For you l qould see for some weeks whether it fix automatically. Thanks for your help!
goodthings
Your's most welcome.
goodthings
Your's most welcome to here.
Rawool8
Beginner Level 4
Should i on Maximum battery πŸ”‹ protection or Basic. Please reply soon.
goodthings
At this time as it is. Thanks.
Same problem facing
