Battery Drain issue after ONEUI6.0 update
(Topic created on: 03-05-2024 08:28 PM)
HammadMaddy
After updating my Galaxy A52 4G to ONEUI6.0 I am having battery issue. Battery is draining faster. Is anyone else having issues with this update?
19 Comments
Talha8089
You should avoid the use of a lot of animations. You must try the power-saving mode.
HammadMaddy
I am already on power saving mode and on 60Hz refresh rate and still i have issues with battery drain..
Talha8089
Dial *#9900#
New page open
Then find
Battery status reset
Click on it
And then exit page
Restart your device
Hopefully it can be helpful 🙂
Talha8089
You can try bettery protect options
It will charge your device at a limit like 90 or 85 percent
rizw6n
Mine is working fine. You may have to wait for the next update to fix this issue in case if it exists as you know most of the times it is something in our own usage patterns which causes the battery to run down quickly.
HammadMaddy
Koi new update a hi na jaye. Abhi tak February ka security patch bhi nai aya to new update ka lamba intezar krna paray ga
rizw6n
Mujhy lagta ab quarterly update per chala jaye ga ye phone.
HammadMaddy
Nai nai bhai. Abhi aik saal para hua hai iss me. I have recieved February Security Patch... Bus thora wait krna hai. Jald hi March wala bhi mil jayega☺️
arslmaqs
UI 6 svcks in every way possible.
