zainmunawar
02-25-2023 09:13 AM in
Hi,
Iam Zain. Iam using Samsung Galaxy a03s.After getting Android 13 update or one UI 5.0 the battery backup got worse and drops around 20 percent battery 🔋 over night.Kindly fix this bug or issue as soon as possible. I am using power saving mode and did all the solution found on internet but in vain.The only solution left is Samsung himself fix the issue with a update.Samsung kindly give your attention to this issue otherwise only solution left is to downgrade back to one UI 4.1 .
Regards,
Zain munawar
2 Comments
USMAN381
02-25-2023 10:09 AM in
Dear this issu face all devises be Patience and wait for next update
And if you downgrade your mobiles security level patch your mobile stop to work and you can't use your mobile any more so please don't downgrade your mobiles software and wait for next update Thanks
JimmyAdam
02-26-2023 09:59 PM in
Yes, please wait or maybe reset to fix
