Battery Drain Issue Of A51
(Topic created on: 06-11-2021 02:31 AM)
HizerMuhammad
After the recent update of the Galaxy A51 4G did anyone faced the battery drain issue. Please comment Down Below so that I can request a query to the customer care
12 Comments
Strangeneria
Turn off vibrations 📳
Sound off lockscreen and keyboards
Check for app updates
HizerMuhammad
It's not because I turned on vibration...its issue with the update
hiltler
Yes I also faced battery drain issue after one ui 3.1 update
souravKhan
Yes, I'm facing this issue after the May security patch update. 🙁
Malkits
no issues new update working fine all
Alappy
Even I'm facing battery draining after the latest update 😩
MK2204
Battery draining issue become worsen after latest update.
Maxel
I'm facing heating isssue...anyone?
HizerMuhammad
No heating issue , but battery Drain
