Resolved! Solved
A51 Battery Drain issue
(Topic created on: 08-20-2020 12:49 PM)
SillyRat
So this phone is brand new delivered on 17th of August  2020.
And I am disappointed with the battery life is giving me. Apps like Instagram are draining like 2% in 4 minutes and zoom took 8% in an hour.
Till 18 google app was using more than 20% in background. I had to disable it and trust me if iI have to disable some functions that are useful then this is not a modern phone.
Am I supposed to disable the main things that make a phone a smartphone.
I WANT A QUICK SOLUTION SAMSUNG!!
I am super disappointed.
And people thinking that I am here to defame Samsung, No its not that I have paid for this phone almost 23k so I can atleast expect some support.
I am adding screenshots too just for reference.
My phone is currently running on one ui 2.1 latest update with altz life.
Help
Resolved!
53 Comments
SillyRat
actually I have completely disabled google.
and guess what
it was still active for 1m in foreground and 1 min in background and it ate up 1.9%.
Should I reset the device??
Ehsank
thanks dear
SillyRat
I never knew that members community would be so helpful.
Thanks to everyone
Ehsank
no dear no need to reset, as this quite natural, Google running in background is necessary sometimes
after all is powered by google
Ehsank
only we need to do is disable background activity
disable data uses
and disable unnecessary notification
Ehsank
ok now , do one more settings
go to settings >
google>
account service >
search, assistant and voice>
google assistant >
click on 3 dot
click on
google activity control
and disable the option
1. Web & App activity
2. Location History
3. YouTube History
As due to these settings on Google always tracking which consuming more battery
SillyRat
Hey eshank,
so I factory reset my phone right now.
lets see what happens later
Ehsank
ok bro do everything wisely
best of luck 👍👍👍
SillyRat
so brother,
My phone lost 11% battery while using Hotspot for an hour in safe mode with display and location off and then after factory reset
in normal mode i started hotshot at 6 p.m. and at 7:19 battery was at 57 with location on and display off
is it justified?
Do you think I should still visit service center or maybe ask for a replacement because if ill take more time these buggers at Samsung will refuse to replace or refund.
I've seen people saying that the battery problem has started from last 2 months but I can't understand what's the problem is it with my device or there software.
Google app is under control but some apps the spotify and snapchat are using more.
overall a bad experience with Samsung as of now
Ehsank
so if you think those app consuming more battery then set as point no. 5 that is restrict background activity and data of and unnecessary notification
and by the way bro for this reason no companies will replace the device.
and do put no.5 settings all those app which consuming more battery
and wait for next update brother
