A34 Battery Drain Issue
(Topic created on: 08-27-2023 11:57 AM)
joomla
Hi Samsung Community, I want to highlight Samsung A34 battery drain quite faster than expected. If you also facing the same issue then raise your concern so that Samsung is aware about it. Not sure whether same issue is with Samsung A54 users or not.
2 Comments
Samsung_specialist
Hello,
Kindly make sure that the device is updated to the last software update, you should diagnose the battery from the settings > battery and device care > battery. Otherwise, you should visit the service center.
joomla
But I recommend Samsung to always do stress testing after running heavy apps and then analyze its battery performance.
