Urgent: Galaxy S23 Battery & Heating Problems After Update
(Topic created on: 09-19-2025 10:55 AM)
Bhavik97
Discussions
I’m facing serious issues with my Galaxy S23 after the recent update:
● The phone is overheating even with normal usage.
 ● Battery is draining extremely fast — with every 30–40 seconds of screen usage, 1% is going down.
 ● I’m having to charge my phone 3–4 times a day, which makes it very difficult to use for daily tasks.
Please look into this issue as soon as possible and provide a fix at the earliest, as it’s heavily affecting usability.
9 Comments
Pawan_Kalyan
Discussions
● Phone is over heating when we turn ON phone
SPS23U
Discussions
Heating issue is very annoying
Lauki
Discussions
Yes True
RĀJ
Discussions
This happened with my phone also. Just try 2 things...
Clear the cache in recovery mode and use app booster app to clean app cache. It helped me. Try this and post your experience
Tarunlamser
Beginner Level 3
Discussions
Yes it's true
Ujjal4928
Discussions
turn on light profile, turn on standard refresh rate 60hz nd customise animation in good lock module home up, turn off 5g nd location too if using location set a routine for location specific apps like delivery or travelling zomato or ola kind, nd also download display assistant in goodlock set all apps to 60 hz it will make ur phone smoother nd reduce heat nd yes at first few hours u will feel the 120 hz missing factor but if u use it daily it wouldn't make a difference ur battery will get saved ur animations will be great nd device will generate less heat
prince2198
Discussions
Itna paisa deke 60hz me phone use krna is justified? Bhai kuch v
Ujjal4928
Discussions
and also turn off adaptive battery, customisation service nd digital wellbeing bcoz they drain alot of battery nd do nothing for u
Samidh22
Discussions
By Monday 12pm in India u will get stable and problems will be solved
