Battery drain
(Topic created on: 06-19-2025 07:58 PM)
Puři
Discussions
Who is facing the battery drain issue? Turning off the home screen limit in power saving mode and turning on adaptive battery it ill fix the problem. You can't keep both of them on
6 Comments
Discussions
Its by defailt off at my end. No battery iasue i faced.
Subham21
Discussions
I am getting better battery life on OUI8 beta than on stable OUI7 on my S25 base variant.
thisisgaurav
Discussions
Facing battery drain issue
Hawkz01
Discussions
Facing a battery drain issue. After the OneUI 8 beta update, I used to get a minimum of 6 hours of screen time, but now I am not even getting 4 hours of screen time.
spa2025
Discussions
Where is one ui 8 beta 2 update
Puři
Discussions
Maybe next month.
