Battery consumption in device idle condition
(Topic created on: 10-07-2022 11:03 AM)
kau1996
Discussions
Samsung its really bad that your os is not even optimised properly for battery consumption.....in device idle condition when screen is off...AOD IS OFF, INTERNET IS OFF THEN ALSO BATTERY CONSUMPTION IS MORE THAN 10% OVERN NIGHT.....AND YES THERE ARE NO BATTERY HUNGRY APPS INSTALLED...please be serious and optimise battery life .....
3 Comments
djprem
Discussions
If you have updated to a beta pls ensure you have cleared cache via recovery. Jumping from Android 12 to 13 is a major overhaul at an OS level.
Draw is around 4%-5%in Oneui 5( android13) which a major gain over 7% -8% in OneUi4.1 ( android12).
Wipe the cache give the phone 48hrs to settle down the new system. You will get much better standby time.
surjn
Discussions
This is Beta Software,
Due to the nature of the test version, unexpected errors may occur
Please make sure to back up important data in advance.
Any errors that are found may be used to improve future versions
IndiaBetaTeam
Discussions
Dear Samsung Member,
Greetings from India Beta Team!
We acknowledge your feedback.
However, we request you to please report this feedback in the Error section, along with the logs. This would help us analyze your issue in a better way.
The path to report error is as below:
Open Samsung Members -> Click on beta banner -> Switch to beta mode-> Beta feedback -> Send feedback -> Error report
In the meanwhile, To resolve your device battery drain issue please visit this link: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
Thank you for being our valued customer.
India Beta Team
