Battery Drain Issues & Poor Camera Quality
(Topic created on: 09-16-2022 06:22 AM)
NikhilJerath27
Discussions
After Beta update, there is huge battery drain and camera image processing becomes very poor. Night mode image not getting saved sometimes.
Also, lag in swipe down notification panel.
8 Comments
sayantan_b
Discussions
You can try performing a factory reset. For me, battery life and camera quality is not that bad. I've performed a factory reset after the update.
Shervin007
Discussions
Agree, no major difference in battery life and camera in beta. I hve also reset my device
surjn
Discussions
Please, do not reset the device. Follow instructions and Phone.
Shervin007
Discussions
Its advisable to do a factory reset when u upgrade to a major Android version. This avoids lot of minor issues and lags.
surjn
Discussions
I'm not doing a factory reset, My phone is quite good running with this testing version.
It's advisable to keep phone data safe and on other devices if someone has to perform a factory reset. Thank you I welcome your suggestions.
VijayJai
Beginner Level 4
Discussions
Same as well as
surjn
Discussions
Hi, We have some Tips. Close all background battery 🔋 using Apps. Open from setting, Battery and device care, Optimized it, check Memory, Free up memory by stopping background apps, and clean it. This might be helpful to you. Thank You.
IndiaBetaTeam
Discussions
Dear Samsung Member,
Greetings from India Beta Team!
We acknowledge your feedback.
However, we request you to please report this feedback in the Error section, along with the logs. This would help us analyze your issue in a better way.
The path to report error is as below:
Open Samsung Members -> Click on beta banner -> Switch to beta mode-> Beta feedback -> Send feedback -> Error report
In the meanwhile, To resolve your device battery drain issue please visit this link: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
Thank you for being our valued customer.
India Beta Team
