Battery Drain Issue After One UI 7 Beta 2 Update on Samsung Galaxy A55
(Topic created on: 04-19-2025 11:30 AM)
anarulkhaled
Discussions
Hi Samsung Beta Community, After installing the second beta of One UI 7 on my Samsung Galaxy A55, I've noticed a significant battery drain issue. The battery life has decreased considerably compared to before the update. I kindly request the Samsung team to investigate and optimize the battery performance in the next update.
Thank you for your support!
Best, @anarulkhaled
5 Comments
KENNEY8
Discussions
Yes
mathur25
Discussions
Yes true. Mine is also significant decreasing after updating to beta 2 in galaxy a55
optimusprime05
Discussions
Yes 100% correct
SankarGovind
Beginner Level 3
Discussions
Yes even i am facing the same issue
SK5619
Discussions
Yes you are right
