Battery Backup while enabling and disabling Maximum power saving mode
(Topic created on: 11-22-2019 02:41 PM)
kkhanduri
Discussions
Received 4th beta update yesterday .
Yesterday I have to went out for a function and the phone was having a charge of about 70%.
Used it for clicking some pics and other stuff after which battery level slides to 46% which is obvious .
Applied maximum power saving mode in a wake to save battery for maximum time . Since I was in party I have to disable and enable to many times and everytime the phone heats up and it took around 3 minutes for enabling and disabling but for my surprise battery was draining at much faster rate than it does in normal mode .
Last tym I send samsung update with the logs and every detail withing 15 minutes of problem but the guys didn't found anything in logs .
4 Comments
S23-RJ
Discussions
same happened with me... they said found nothing in the logs about battery drain
syedfaisal
Discussions
facing same battery drain problem. specially while using camera BATTERY drain drastically after bata 4 update Samsung plz fix this issue
kkhanduri
Discussions
yes you are right , updated my last logs again let's wait what they find in them , otherwise have to submit a vidio
arunnechlani
Discussions
I was facing the same problem but after doing reset on 4th beta update I am getting 7 hrs SOT and idle time going almost 2 days. I would suggest reset once to get battery on normal life
