How to manage good battery health for AO5
(Topic created on: 02-06-2025 08:33 AM)
BN101
Consumer Electronics
Please help me how to manage battery help
BN101
Does the the A05 support wireless charging??
ngonidzashe
2/6 Optimize Apps & Background Usage
Put Unused Apps to Sleep:
Settings > Battery & device care > Battery > Background usage limits
Add unused apps to "Sleeping apps" or "Deep sleeping apps."
ngonidzashe
Check Battery Usage:
Go to Settings > Battery & device care > Battery > Usage and identify apps using excessive power.
If an app drains too much, try restricting background activity.
Disable Auto-Sync for Some Apps:
Settings > Accounts and backup > Manage accounts
Disable auto-sync for apps you don't need to update constantly.
ngonidzashe
3/6 Reduce Battery Drain
Lower Screen Brightness: Use adaptive brightness or manually reduce brightness.
Use Dark Mode: Settings > Display > Dark mode (helps on LCD screens too).
Lower Screen Timeout: Settings > Display > Screen timeout and set it to 30 seconds or 1 minute.
Disable Unused Features: Turn off Bluetooth, Location, and Wi-Fi when not needed.
ngonidzashe
4/6 Manage Performance & Heat
Avoid Overheating: Heat damages the battery over time. Keep the phone cool and avoid using it while charging.
Disable 5G When Not Needed: If you use Wi-Fi most of the time, switch to LTE/4G in Settings > Connections > Mobile networks.
Use Power Saving Mode: Settings > Battery > Power saving (turn it on when needed).
ngonidzashe
5/6 Keep Software Updated
Updates improve battery efficiency. Check for updates in Settings > Software update > Download and install.
ngonidzashe
6/6 If Battery Drain is Abnormal
Restart the Phone regularly (every few days).
Check for Rogue Apps: Boot into Safe Mode (Hold power button > Long-press "Power off" > Tap "Safe mode"). If the battery lasts longer, an app is causing the drain.
Factory Reset as a last resort if issues persist.
Munatsi399
In addition you can also allow you device to restart on its own as it optimizes....
ngonidzashe
That's true.... thanks for additional infor
BN101
How can I do this
