advice for better battery performance
(Topic created on: 04-13-2020 06:32 PM)
CipherF10
Community Guidelines
Don't let your phone's battery to drop below 20%. Charge your phone as soon it reaches 20% doing this will improve your battery performance and keep the battery healthy.
7 Comments
arunnechlani
Follow this it may help even further with battery performance.
https://r2.community.samsung.com/t5/Tech-Talk/Battery-saving-tips/td-p/2920797
Satish1421
Valuable information about samsung devices Thank You
Not applicable
to get better battery life let battery to drop 0% then charge it to 100% only..this is only the perfect method to save battery life
CipherF10
using phone below 20% is very bad for the battery life. it slowly decreases the life of battery.
Ashwin98
The idea which was given by cfvishal is for regular use and the other by interchupipi is for one time to recalibrate the battery...
Devv_007
Batteries works best in 20 to 80 range.Cuz voltage is constant ,not too high or low.
Source-Batteryuniversity.com
CipherF10
true
