M21 Battery draining issue
(Topic created on: 01-05-2022 10:47 PM)
Kiishan
Community Guidelines
Regretting for updating my phone for dec patch. I shouldn't have updated. the battery drains faster.
idk what to do, all I can do is just wait for the next update that's all.
2 Comments
samsung_users
When you facing problems about draining battery, please follow the steps:
1) Bring out the SIM card you don't use.
2) Switch off Wi-fi, GPS and bluetooth if you don't use.
3) Don't increase brightness more than normal.
4) Set the screen timeout less than 1 minute.
Settings> Display> Screen timeout
5) Uninstall the unused apps.
6) Keep the background running apps in sleep
Settings> Device care/ Device maintenance> Battery> Save power
5) Put the phone in charge when the battery level in 20%-25%
6) Don't overcharge the phone when the charge will be completed.
7) Switch off Mobile data when you don't use your phone.
I hope it helps you.
cs-member13
Expert Level 4
Dear Samsung member,
Settings > Select Device Maintenance/Device Care > Optimize > Optimize all options like Battery, Storage and Memory
Kindly turn off the smart features of the device and other connectivity features when not in use, which will eventually help you to reduce battery power consumption (smart features such as Motion gestures in advance feature and Bluetooth, Wi-Fi, Hotspot, etc.).
Please follow the below steps:
2. Tap on Bluetooth, Location/GPS, Wi-Fi, Mobile hotspot, NFC, etc. to turn off.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report).
Warm regard,
